Signal Conditioning
Can I use the SCB-68 together with a NI6703 to attenuate the 16 AO channels
Is it possible to use a SCB-68 to attenuate the 16 analog output signals
from a NI6703. I am trying to build a multichannel thermocouple simulator.
If it is possible where shall I put the resistors? The SCB-68 manual only
describes the case with the two AO channels that normally exists on a DAQ
card
Software Details: LabVIEW version 7.1
NI Hardware : Multifunction DAQ device PCI-6703
Driver Version : NI-IMAQ
Operating System: Windows XP
(3,187 Views)
Hello atoanha!
It is possible and you should put your resistors on the board.
cheers.
Ashwani S.
National Instruments Sweden
(3,162 Views)
