Signal Conditioning
Can not get analog input with SCC-SG04
I have used the wizard and wrote a simple AI input channel loop with a digital readout. The voltage doesn't change.
(3,544 Views)
Well, I guess I'm not sure what all you have tried or how you have things set or configured. I would first try verifying the input through the test panels in MAX. Make sure you have your DAQ card set to NRSE mode, make sure you have your SC termination equipment set as the "Accessory" to the DAQ card under it's properties, double check your connections, then see if you can read the voltage through the MAX test panels. After you can read the voltage there, then you can try using a program. I hope this helps!
Russell
(3,544 Views)
Thank you for help. I overlooked setting the property of the accessories.
(3,544 Views)
