Signal Conditioning
What NI product can I use for my application?
need a NI transducer for an omega thermistor (input 2252 Ohmn output 0-5V)
I have a NI DAQ and I want to connect the thermistor output.
(3,298 Views)
Most NI boards will handle 0-5V.
Your concerns now become how fast?
How precise?
What type of interface (ie PCI serial, PCMCIA, etc)
Ben
(3,298 Views)
Lina;
Most of NI DAQ boards are compliant with 0-5V inputs. The information you need to put together in order to select the best DAQ board to it, are:
- how fast the sample rate needs to be
- how many transducers you will hook up at the DAQ board
Hope this helps.
Filipe A.
(3,298 Views)
