Signal Conditioning
Cernox HT RTD
I am using Cernox HT RTD. The sensors are potentially at a very high voltage, approx 30kV isolation.
Could you please suggest an appropriate signal conditioning model with the requisite isolation level.
Regards
Prabhakant Patil
(6,045 Views)
30kV + security margin is tricky.... usual isolation boards I know of are limited to 5kV
Would it be possible to use  a battery powered RTD reading device with rs232 output and use a rs232 optical fiber wire cable?
Greetings from Germany
Henrik
LV since v3.1
(6,019 Views)
