Signal Conditioning
configure SCB-68 in NI-DAQmx
Hi, thanks for reading this!
I am starting to use a piezo device which has been used couple years ago by a former group member. The LabView program the former person wrote looks fine, but I just couldn't get the right voltage pulse.
We have a NI PCI-6713 and a SCB-68 connector block. Under the Measurement and Automation Explorer-->Devices and Interfaces, there are both NI-DAQmx and Traditional NI-DAQ (Legacy) Devices and PCI-6713 appears under each of them. But when I look at properties of the PCI-6713, for the one under Traditional DAQ, I can add SCB-68 as accessory, but for the one under DAQmx, there is no choice other than "none" under the accessory tab and the "configure" button cannot be pressed.
So I think that might be the reason why I cannot get the right signal, so I am wondering how should I configure the SCB-68 for the PCI-6713 under NI-DAQmx. Any help would be appreciated!
(5,821 Views)
There's really nothing to configure.  It is a connector block.  Nothing more.  All you need to do is figure out which pin to connect your signal to.
(5,820 Views)
