Signal Conditioning
Conditioner wiring?
I have a MID 7652 and need to wire in my TMO-2 signal conditioner, but am not sure which input or output to use, please help.
(3,753 Views)
Generally, you will see 4 inputs to a load cell conditioner, EXE +/- and SIG +/-.  The EXE +/- are the positive and negative terminals for the excitation voltage. The SIG +/- terminals are the inputs for your load cell.  The output of your conditioner can then be wired into the analog input lines on your MID.  Documentation for this device can be found here.
Jasper S
(3,733 Views)
