Signal Conditioning
High gain High bandwidth current amplifier
I'm doing a biology experiment with patch-clamp amplifier to measure the bio-signal.  Basically we need a current amplifer with a gain about 1pA/mV or 10^9 V/A. The bandwidth should be about 1MHz. We currently have the patch-clamp amplifier with this high gain but only has 100KHz bandwidth. Can anybody know how to improve this system? Or where can I buy such high bandwidth current amplifier? Thanks a log.
(4,892 Views)
10^9 at 1MHz is quite a bit to ask.
Here's 10^7 at 1.8MHz:
http://www.femto.de/index.html?../products/lca.html
Maybe you could follow this unit with a wideband  voltage amplifier with a gain of 100 to complete your needs?
(4,885 Views)
Thank you very much for suggestion. Will this combination of current amplifier+voltage amplifier be possible to achieve what I need with low noise?
I'm worrying too much noise that I can't filt out original signal.
(4,880 Views)
You may want to contact Femto directly and discuss your application and noise requirements with them.
Proper detector and wiring shielding and grounding are important at achieving high gain/bandwith product with low noise.
Good Luck
-AK2DM
(4,862 Views)
