Signal Conditioning
Filter Point by point
 I’m trying to understand LabVIEW filters and the application of point by point filter and a nom PtByPt filter.I attached an example where I applied two Butterworth filters (one is a PtByPt and another isn’t) to the same signal. My problem is, the filtered results should be the same and in this example they aren’t. Can anyone, please tell me what is wrong in my code?
Message 1 of 15
(11,191 Views)
here is a small but important change 😉
Make yourself familar on how numerical filter work.ALL filters have some kind of memory , if not every single value represent just a DC value 😉
The pt by pt filters are nice if you want a pt. by pt update of a value while you have a not so fast samplerate.
Greetings from Germany
Henrik
LV since v3.1
Message 2 of 15
(11,184 Views)
Hi Henrik,
I forgot to mention, I’m using LabVIEW 7.0. Could you save your changes in LV7.0 version, please? So I could open it. Thanks 🙂
Message 3 of 15
(11,177 Views)
can't backsave to 7.0, so here is a picture. Basically i wrapped the ptbypt filter with a loop and swapped it with the index.
The difference is in the range of e-17 🙂
uups a bug in vi snippet? the input cluster for the  sine waveform should be filled with your values....
Message Edited by Henrik Volkers on 04-01-2010 10:19 AM
Henrik
LV since v3.1
Message 4 of 15
(11,163 Views)
Thanks alot for your reply, It works very well. Smiley Happy
 But still, why I can’t apply the PtByPt filter to a single value as I did in my first example??
Message 5 of 15
(11,151 Views)
See my first answer.
Henrik
LV since v3.1
Message 6 of 15
(11,111 Views)
Dear
Message 7 of 15
(6,716 Views)
Hey, you found out that for numerical filters the ratio of fc/fs is the important fact 😄
In numeric signal processing you often normalize fs to 1 ;),
in that case both filters behave the same (for the numerical array).. even if in your vi the filter artifact at the beginning looks different, but that's because of different filter init conditiotions in your vi (loop) .. should be the same in the first run 🙂
Henrik
LV since v3.1
Message 8 of 15
(6,709 Views)
Dear
Message 9 of 15
(6,706 Views)
Sorry. I didn't get what you wan to say/achieve...
Some basic lectures on digital signal processing/digital filter design are always a good idea if you deal with data aquisition 🙂
(mine are about 30a ago 😉 )
Henrik
LV since v3.1
Message 10 of 15
(6,698 Views)
