Signal Conditioning
Filter per channell or board level for SCXI 1100
I had a question relating to the SCXI 1100 that I was hoping someone might be able to help me with.
The SCXI module shows that there is a programmable filter and I am curious if the filter is on the board itself or does each channel have a filter that can be configured.
I have a strong feeling from the documentation that the filter is on the board itself but just curious if anyone else knows.
Andrew.
(3,209 Views)
The filter is onboard in SCXI 1100.
But, each channel does not have its own filter. read this link to understand this better
But you can build your own front end low pass filter for each channel as described here
(3,200 Views)
