11-22-2005 09:12 AM
11-22-2005 09:36 AM
I am sorry i forgot to attach the document.
This post has it! PLS HELP ME OUT!
11-22-2005 10:45 PM
Hi Krithika,
for Q1: Modify the attached VI for your application and use it.
It performs simultaneous Ai/ AO and so, you will have better synchronisation.
In the same vi, i have inserted the generated signal array into the acquired signal array ands so you will get them on same graph.
For Q2: for filtering, use any software filter provided in labview.Just study the characterstic of your noise and use a suitable filter.Find this in functions-> analyse-> signal processing -> filters.
Q3 : for point by point analysis i suggest you write data into a file and do analysis offline !
Note: i advise you to do filtering on saved data instead of filtering during acquisition because since filtering also takes up process time and might affect your acquisition/generation.
But if you do not get any acq buffer related problems, go ahead and perform filtering during acquisition itself.
regards
Dev
11-23-2005 05:11 AM
Hi Dev
Thank you so much for the quick response. I am looking at the AI-AO Vi that you sent me and I guess will contact you if i have some questions. But I have one other question.
If you see the output that i sent you- I am not able to visualize the sine (diplacement ) at higher freq, say 100 HZ. Fro my application i need to play around with the Frequency ( range 1 HZ to about 100 HZ) and view the displacement on LABVIEW in real time.
So i will need to add the filter during data acquistion. I wanted to first subtract both the signals ( generated sine wave and the diaplacement) and see how different they are and view it on a graph. But as my diaplaced signal is a trasponsed array i am having difficulties with it.
Pls give me your suggestions.
Thank you so much once again for all the help so far.
Best Regards
Krithika
11-23-2005 05:33 AM
Hi Krithika,
Correct me if i understood you wrongly. When you said "i am not able to visualize the sine (diplacement ) at higher freq, say 100 HZ." do u mean, that you are not able to generate a sine of 100 HZ??
If its so, you should be able to achieve this by selecting suitable buffer size, cycles per buffer and update rate.(buffer size= 10000, cycles /buffer 100 and updater rate 10000) and this should give you this desired sine wave of 100 hz.
regards
Dev
11-23-2005 07:16 AM
Hi Dev
No what i mean is that the noise in my displacement signal is high. I did not mean to the generated sine wave using labview but the analog input sine wave (from the strain gauges on my motor).
Krithika
11-23-2005 01:57 PM
12-01-2005 02:31 PM
Dear Dev
Thanks for the Suggestion. I did what you said and the sine wave looks great. But i am having trouble when i got to higher frequencies. With 10 Hz the output looks great. But at say 100 HZ i am not able to see the sine wave (Analog Input- The acquired data ) at all.
Pls help me out.
I have attached my VI with this email.
Best Regards
Krithika
12-01-2005 02:34 PM
Hi Ryan
Thanks for the email. I did try to look at the acquired signal at 100 Hz using an Oscilloscope i can see the sine wave but its distorted.
No i don't have access to hardware filters.
I have posted the updated VI , what Dev had suggested and i am able to see a better Sine wave at 10 Hz but no luck at higher frequency.
PLS HELP ME OUT.
Best
krithika
12-01-2005 10:53 PM
Hi Krithika,
In your Attached VI, For AO write, i made update rate as 10000, Buffer size as 10000 and cycles per buffer as 100
And i got a 100 Hz signal of quite good resolution.
I have made vasues defaut in ur VI tha ti have attached, so run it and check it out.
Dev
