Signal Conditioning
Full bridge strain gage shunt calibration
The shunt calibration DAQmx wizard provides the option to select one of the bridge completion resistors to shunt for the calibration. How should I select which one will be used for a shunt calibration of a full bridge III configuration? I'm using an NI-9237 bridge measurement module.
(2,915 Views)
We also use the NI-9237 and as far as I know, the only settings which can be adjusted are
  • excitation voltage and
  • enable half-bridge completion
by right-klicking on the cRIO-Module in the Project tree.
Good luck
(2,889 Views)
Hello Testr00,
You can find more information in these documents: Connecting Strain Gages and Shunt Resistors to the NI-9237 and Measuring Strain with Strain Gages.
I hope this information is useful for you!
All the best,
(2,883 Views)
