Signal Conditioning
High speed acquisition vi
Using PCI 6035, SCXI 1001, SCXI1125 2 channels (AI)and SCXI 1124 2 channels (AO), i am trying to write a vi, but comes out with errors above sample rate of 100 (given to AI, AO config blocks).
I want to write a vi which will not generate errors and should be capable of running at sample rate of 1000 for both AI and AO channels simultaneously.
The application needs to measure AI value and then send out AO value for control purpose. This has to be repeated 1000 times in a single second.
(3,009 Views)
Do attach your Program, and tell us what errors it is generating.
From what you describe, It looks like you are doing a single point(finite)AI read and based on it, are doing a single point AO write.
if this is what you are doing, then the number of times you can repeat it depends on your system's processor speed.
regards
Dev
(2,999 Views)
