Signal Conditioning
What parts are required to use a CB-68LPR in a CA-1000?
I want to use a CB-50LP, CB-68LPR, or SCB-68 in a CA-1000.
Is there an NI part number for a ribbon cable that goes from the CB-50LP to the back of the CA-1000?
Is there an NI part number for a ribbon cable that goes from the CB-68LPR to the back of the CA-1000?
Is there an NI part number for a ribbon cable that goes from the SCB-68 to the back of the CA-1000?
How does the connector blocks mount to the bottom of the CA-1000?
Are there predrilled holes in the CA-1000 for mounting the connector blocks?
Are mounting screws provided?
Kevin.
(3,293 Views)
Hi Kevin,
One way you can find more information on the CA-1000 is to search our website.
I found some of the following links which you should find helpful.
Product Manuals: CA-1000 Configurable Connector Accessory Enclosure Installation Guide
Probably the best thing you can do though is to contact one of NI's Technical Sales Representatives as they know the best configurations, prices and connectors for our various devices.  They can give you more complete information on your system specs and costs than is easily found on your own.
(3,285 Views)
