Signal Conditioning
How can I acquire 0-10vdc signal on a PXI-6221 card when it is used by SCXI-1520 in a combo chassis PXI-1052 at the same time
My hardware is :-
PXI 1052 combp chassis - 1no.
PXI 6221 M series multifunction card with scb 68 connector box - 1set
SCXI 1520 (strain card) with + SCXI 1314 connector box - 1 set
Aim :- To acquire strain signal from SCXI 1520 and acquire 5 nos. 0-10 vdc signals from SCB 68 simaltanously.
Probelm:- When I try to acquie 0-10 vdc signal by mentioning PXI 6221 ai chnnels, i got message "Specific resources are reserved"
Please tell me the solution!
Best regards
(5,668 Views)
Hi S_Kanchap,
The PXI 6221 uses ai0 for SCXI in multiplexed mode. So if you use any other analog input line and make sure the 1520 is operating in mulitplexed mode, you should be able to use all your other analog input lines.
Please let me know if this works.
Abhinav T.
Applications Engineering
National Instruments India
LabVIEW Introduction Course - Six Hours
Getting Started with NI-DAQmx
Measurement Fundamentals
(5,656 Views)
Thanks Abhinav for quick reply, although I am checking in multiplexed mode and I have checked ai1 to a17.
Yet I will check it again after going to my site in a day or two.
or
Will you check and confirm me by testing in office because i want to visit my site after finding solution? my email id is sk@reckersreckers.com
Waiting !!!
Warm regards,
(5,655 Views)
Hi S_Kanchap,
Please ensure that you have added the voltage and strain channels to the same NI-DAQmx task.
I tested your setup and got the error you are receiving only when I made 2 separate tasks for them. As soon as I added them to the same task everything worked correctly.
Abhinav T.
(5,652 Views)
