Signal Conditioning
How can I make the SCXI1100 example works
I am designing a system with SCXI1100, SCXI 1303, 9 type T thermocouples, and labview 7. I want to use the example SCXI 1100 that comes with labview. It seem it does not work? Please give me some detail about how to make it work.
thanks
bim
(3,176 Views)
Bim,
To help troubleshoot your problem can you provide some details? What DAQ board are you using? Which version of NI-DAQ are you using? Are you receiving any error messages? If so, what are the error codes/or numbers? Have you been able to test the signals correctly in the Measurement & Automation Explorer (MAX)?
Have a great day.
(3,176 Views)
