Signal Conditioning
How can I read the value of an SCXI-1124 channel in LabVIEW?
Is there any way to read back the value of an output channel of SCXI-1124 in LabVIEW (version 6.1 or 7.0)? I want to sweep the output gradually, and want to avoid a sudden change. But this is difficult if the current status of the channel is unknown. Especially, when the computer is reset or shut down, the SCXI-1124 maintains the output voltages (which is good for my application), but I have no idea what those values are.
(3,051 Views)
If I understand, you can look in the MAX. Then, in the pheriferal you can find the Ntional Instrument Card inserted into the PC. When you test this card you can read the input signales of the card( Volt in general)which is the out put of the SCXI.
regards
Anwar
(3,051 Views)
