Signal Conditioning
How can i read the state of the SCXI-1160/1127
The SCXI in configured in NI-DAQmx
I use CVI 7.1
Now i want to readback the state of the cards (which line is set or which channel is selected)
(2,938 Views)
If I understand your question, you should look the MAX, then you will find the cards. There, you can find the test option that helpes you having the iformation about the state of the cards.
regars
Anward
(2,938 Views)
