Signal Conditioning
How can i control a slider with a button.
Is it possible to control a slider with a button? It works like a automatic sliding gate. Is it possible? Where when you open the gate, it will slide slowly.. And can anyone help me with this..
(6,895 Views)
Hi EzaL,
Let me see if I understand it correctly.  You have two controls on the front panel: one is a slider, and the other is a button.  If the button (gate?) is pressed, the slider slowly changes value (down).  Is this correct?
If so, you can use property nodes and a timer to do this.  Create a property node for the slider with two elements: disable and value.  See the attached vi as a possible solution.
Hope this helps
Darrel
Message Edited by Agile on 05-31-2009 01:24 PM
(6,779 Views)
Agile has supplied a great answer, with code. I doesn't get any better than that.
I wish one-hit-wonders would at least check back in and say Thanks when help is offered.
Richard
(6,750 Views)
Thanks!  I and understand why the original poster hasn't replied.  It's been six weeks and no one answered him.  *sigh* At least it's there for the greater community.  If someone ever does a search on slider control, they may find this.
Kudos!
(6,738 Views)
Agile wrote:
... been six weeks and no one answered him...
True, he probably gave up or hasn't checked his email, so to him (her?) I'm sorry for jumping the gun, but I have seen too many of these members that log in once or twice and get good answers and don't check back in. It erks me. You make a good point though, that the thread has a wider purpose than that of helping the originator.
Richard
(6,734 Views)
