Signal Conditioning
SCXI 1520 quarter bridge setup will not output excitation voltage, but full bridge will
My SCXI system will not output an excitation voltage to the quarter bridge(verified with voltmeter). It works for a full bridge setup. When connected to a 'quarter bridge I' configuration, I can use MAX to null and shunt calibrate. The quarter bridge circuit appears to be balanced after the calibration, but the calibration results post a software gain factor close to zero, as well as a close to zero excitation voltage (eventhough I have the voltage configured for 5 volts). I have the SCXI 1520 module, the virtual channels, and the wiring properly configured (several years experience with this device). I'm using an old E series DAQ card AI-16XE-50, with the 50 pin cable that plugs in the back of the SCXI chassis. I noticed I had two bent pins with the cable connector module that plugs into the SCXI backplane.  I was able to straighten them, so the cable connects properly, but I suspect the bent pin incident caused electrical circuit damage. Any suggestions on trouble shooting? None of the three 1520 modules I have will output an excitation voltage for a quarter bridge.
(6,682 Views)
Sorry that I don't have an answer for you tyea, but I'm interested in your thread because I have a similar issue with a 1520. My excitation votltage, as measured with a DVM, is always 1V. I've tried 0V, 1V, 5V --- it's always 1V, on Full or Quarter bridge. I'm using a similar DAQ to yours - a PCI 16XE-10 (and a PCI-6030E on antother system).
I don't have a lot of experience with these modules. This could be a wiring or programmatic thing I'm doing wrong.
Richard
(6,667 Views)
This could definitely be some type of hardware failure though it's highly unlikely.  I would recommend both of you take a look at this KB and see if any information provided there can help you determine what's actually happening with your excitation voltage.  Let me know once you've done the testing with an ammeter.
David Pratt
Group Manager for Application Engineering Specialists | Automated Test
NIC
(6,657 Views)
