Signal Conditioning
How correction factor works in DAta compression
Hi all,
I am trying to reduce data recording rate by using Sample Compression  vi''s reduction factor from 1 kHz to 1Hz. Seems worked to 10Hz but couldn't be lower the rate.
Here is the results
Correction factor(Size)     Data size
     1     (1k)                           60000 data point/min- 1kHz
    10   (100)                          6000
    100  (10)                           600
   1000  (1)                            600
  10000(.1)                            600
I have no idea why.
Jae
(7,284 Views)
Hi Jae,
If I may ask how are you getting the data sizes, and are you using the Sample Compression Express VI. It would help more if you can post your code.
You might also want to take a look at the Resample Waveform VI
Best Regards,
Faris
Bueller
(7,263 Views)
