Signal Conditioning
How do I use Print Panel funtion to print running VI panel one time?
I have a complex VI with numerous on screen parameters of a running jet engine . I would like to print the panel programatically with a control (button). Have tried the Print Panel function but it runs continuously. I need to make it print once and once only for each "button press".
Thank yous
C.Kollett
Falcon AeroSystems, LLC
(3,459 Views)
Hi Charles,
I created an example that allows the VI to run continuously and still be able to print the VI for each button press.
My best advice for you is to run your VI in "highlight execution mode" by click in on the "lightbulb" found in the toolbar of the block diagram. When you run your program you will see how the data flows and why the VI is being called several times.
Take a look at this example, I think it does what you need.
(3,459 Views)
Excellent support. Thanks. The example works fine.
Rgds
Charles Kollett
President
(3,459 Views)
Can you send the same attachment in Labview version 6.0
(3,459 Views)
