Signal Conditioning
Information on acquiring data.
I'm using SCXI 1102c for pressures and flows (192 channels) and also SCXI 1102 for temperatures(96 channels). The data will be sent to disk raw. Should I generate some sort of header with the raw data file that contains information to scale the data? Cal constants, gains, etc...
(3,587 Views)
Greetings,
You will need to retain a couple of pieces of information to convert your binary data to scaled data. I think KnowledgeBase 202GJK5I does a good job of addressing this issue:
When Using the Analog Input DAQ Functions, How Do I Convert Binary Data to Scaled Data (Voltage Valu...
Good luck with your application.
Spencer S.
(3,587 Views)
