Signal Conditioning
How do you use a hall effect sensor to act as a trigger to start the aqusition of data ?
On a 4 stroke engine, a hall effect sensor acts as a trigger to instigate the aquisition of data. Data is recorded from a pressure transducer on both the compression and exhaust cycle.
(3,519 Views)
Paul,
Here is a great resource the help you get started:
http://zone.ni.com/devzone/devzone.nsf/webcategories/327C75ED77E1B8E5862567E80051CF83
Additionally, if you need more help, please supply information such as:
1. What daq board are you using?
2. What kind of signal does your hall effect sensor output?
3. What have you tried?
Best Regards and good luck!
(3,519 Views)
Daer AnujD many thanks for your posting. The resources that you have noted are very good and I will be spending some time reading over them.
Thanks once again
Paul Briozzo
(3,519 Views)
