Signal Conditioning
I can't adjust the properties of my SCXI-1531 module in MAX
When I right-click on the module name, the Properties option is grayed out. I want to adjust gain, filter, and current source settings for each of my channels.
(3,294 Views)
Have you tried power cycling the chasis, or even just deleting it from MAX and then adding it again? Have you tried power cycling the computer? Are you doing this in Traditional or DAQmx? What DAQ card are you using?
(3,294 Views)
Hi George,
Thanks for responding to my question. I actually ended up talking to NI support, and apparently there's a bug in the software. The problem can be rectified by going to Data Neighborhood in MAX, creating a task, and setting properties from there.
(3,294 Views)
