Signal Conditioning
How to configure my SCXI-1520 in parallel mode using NI-DAQmx
I am using SCXI-1520, PXI-6070E DAQ card and PXI-1011 Chassis.How to Configure my SCXI-1520 in Parallel mode using NI-DAQmx? When i am using DAQmx for Configuring the SCXI-1520, Operating Mode option is getting "Grayed". Why it is Happening? Kindly give me the brief steps to Configure SCXI-1520 in Parallel mode.
Thanq
(3,240 Views)
The PXI-1011 chassis has a sealed, high-voltage backplane on the SCXI side. Therefore, you cannot connect a DAQ card directly to the SCXI modules as you normally would for parallel mode operation. If you need to use parallel mode, I recommend that you use one of our PXI-1010, SCXI-1000, or SCXI-1001 chassis.
Bill B.
(3,240 Views)
