Signal Conditioning
How to configure my SCXI-1520 in parallel mode using NI-DAQmx
If I am using SCXI-1011(otherwise SCXI-1000) Chassis, How can i Connect the Signals from the Backplane to DAQ card directly? Kindly give me the detailed answer...
(3,358 Views)
Avasarala,
Thank you for contacting National Instruments.
If you would like to connect to your your DAQ board directly when using SCXI, you will need the SCXI-1180 feed through panel and the SCXI-1302 terminal block. The SCXI-1180 connects to the 50-pin connector on the side of the SCXI-1349 adapter which connects your DAQ board to SCXI chassis.
Here are links to the products:
http://sine.ni.com/apps/we/nioc.vp?cid=1645〈=US
http://sine.ni.com/apps/we/nioc.vp?cid=1690〈=US
Bill B.
(3,358 Views)
Avasarala,
If you are using a PXI-1011 chassis, you can access all of your other input signals from the front connector of your DAQ board.
Bill B.
(3,358 Views)
