Signal Conditioning
How to reversible tie up pins in FT01 ??
for daq in DIFF-Mode I allways have to tie the (rel.) negative pin via a 100kOhm-Resistor to AIGND.
I want to use some FT01 with preconnected pins.
If I open the FT01 I can see a matrix of holes, they seem a good place for the action, but how?
(3,090 Views)
Hello;
I'm assuming you are talking about the SCC-FT01 signal conditioning module.
If that is the case, the SCC modules route their negative leads to the AIGND of the DAQ device, so, you don't need to make that connection externally. Just make sure to configure the DAQ device as NRSE.
Hope this helps.
Filipe A.
(3,090 Views)
