Signal Conditioning
I NEED CONFIGURATE THE SCXI 1000 CHASSIS, SCXI 1120 MODULE WITH DAQ PC-LPM-16-PnP
HI, I HAVE PROBLEMS FOR CONFIGURATE THE SCXI 1000 CHASSIS AND THE SCXI 1120 MODULE WITH THE DAQ PC-LPM-16-PnP.
THANKS FOR THE HELP IN THIS CASE. MY SYSTEM IS THE FOLLOWING:
1. SCXI 1000 CHASSIS, SCXI 1120 MODULE AND SCXI 1320 BLOCK TERMINAL.
2. THE DAQ PC-LPM-16-PnP.
3. NI-DAQ VERSION 6.8
4. LabVIEW 7 EXPRESS
5. WINDOWS ME.
MY PROBLEM IS : IN THE NI-DAQ, I ADD THE SCXI 1000 CHASSIS, BUT NI-DAQ NO IDENTIFIES THE SCXI 1120 MODULE!! WHAT HAPPEN??
MOREOVER, IN "DEVICES & INTERFACES" I INSERT THE SCXI 1120 MODULE IN SLOT 1, AFTER IN THE CHASSIS I TO DO "TEST" BUT APPEAR THE FOLLOWING MESSAGE:"FAILED TO FIND: THE SLOT 1 IS EMPTY". WHAT HAPPEN?
HOW I CONFIGURATE THE SCXI 1000 AND THE SCXI 1120 WITH THE DAQ PC-LPM-16-PnP????
THE SCXI 1000 AND 1120 IT'S COMPATIBLE WITH THE PC-LPM-16-PnP???
THANKS!!!!!
GOOD BYE!!
(3,610 Views)
Hello Andres,
Thank you for contacting National Instruments.
The SCXI-1000 and 1120 are compatible with the PC-LPM-16PNP. They are supported in NI-DAQ up to version 6.9.3. Please try upgrading to NI-DAQ 6.9.3. You can download this driver at: http://digital.ni.com/softlib.nsf/MainPage?ReadForm&node=132010_US .
Let me know if this does not help.
Sean C.
Applications Engineer
(3,587 Views)
Hello Andres,
After further research, I discovered that the PC-LPM-16-PnP cannot be used with SCXI. This configuration used to me supported with the SCXI-1342 adapter, which is no longer manufactured.
Unless you have this 1342 adapter already, you will have to upgrade your DAQ board to control the SCXI Chassis.
Sean C.
(3,585 Views)
