Signal Conditioning
I need to make an FFT from stored data
I need to make an FFT to a stored data in a csv file, It has 2 colums, the frist one is time and second is the amplitude, I am reading the date and making a cluster with the two columns with that i can plot easily in the time domain but I can not find some block to make an FFT from an this cluster. can you help me?
(3,149 Views)
Accepted by elfredy91
The (math) FFT.vi wants an array with constant samplerate and the samplerate.
The signalprocessing FFT(s) work with a wfrm (cluster of y value array, and a dt value)
If the samplerate wasn't constant,  you need to resample the data.
Reading the HELP of the FFT.vis helps 😄
Greetings from Germany
Henrik
LV since v3.1
(3,096 Views)
