Signal Conditioning
Is there an easy way to detect the difference between IEEE 1451.4 V0.9 and V1.0 TEDS sensors?
We are developing a Labview application for TEDS based accelerometers. Is there an easy method for determining if the sensor is IEEE 1451.4 V0.9 or V1.0? Thanks.
(3,545 Views)
The LabVIEW TEDS library has VIs that read the template IDs from the TEDS bitstream. If the ID is < 25, its a legacy TEDS sensor (i.e., v0.9). otherwise its V1.0
Rajesh Vaidya, Ph.D
(3,545 Views)
