pmac,
From the research that I have done, you should be able to read that file and write the file using the binary file I/O VIs. You do need to know the format of the file however to read it. You might try to just read it first and work from there. Do you get permission errors when trying to read the file as well? Do you have problems reading and writing other files? Do you have a small test wft file that you might be able to post?
Let me know!
Andy F.
