Signal Conditioning
Load cell calibration with various gains
I am anticipating a problem with some data that has been collected from a load cell. The load cell has been calibrated with known loads at a gain of 1000 db.
There is the unfortunate possibility that the gain was altered during data collection (potentially to 5000). My question is, in LabVIEW how can I:
1) check the gain of the signal?
2) fix this issue if it occurs....? Is there a "simple" way to normalize the signal to the gain? Or can I just re-calibrate the load cell at that gain level?
All thoughts are welcome. Please be kind.
-MillionHorns
(2,870 Views)
I want a 1000 db amplifier !!
I have worked in the range of 1e6(+-2)  (PMTs :))   but never with 1e50! 😄 😄
Most modern amplifiers have a digital interface ...
Offset voltage ... noise level, could be indicators ...
Measurements that haven't been (comletely) documented where never done 😉
Usually one would need a calibration for each used setting.
Greetings from Germany
Henrik
LV since v3.1
(2,854 Views)
