Signal Conditioning
USB-6001 AO Amplifier
Hi to everyone!
I am currently working with a USB-6001 NI DAQ module, and I need to apply a controlled voltage to a certain load. For this application is needed 500W and a regulated voltage of 0-100V in a range of 50-60Hz.
So, I need to supply 0-100V controlled by the DAQ output +-10V (very low current - about 5mA) analog signal.
There is any kind of way to amplify this +-10V analog signal to 100V (500W)?
(3,915 Views)
For AC only the cheapest method would be a 'hifi' amplifier.
Power and frequency range also fit to an motor converter .... (and use two analog out to set frequency and voltage, or control it by a digital interface ...)
You didn't say a word to the kind of load you want to drive. That is important!
For a simple heater one could thing of other solutions...
We use BEAK amplifiers a lot.. for specific questions I would send them a mail or pick up the phone:
http://www.beak-electronic.de/en/analog-power-amplifiers/500-w/baa-500-beak/
Greetings from Germany
Henrik
LV since v3.1
(3,908 Views)
Thanks for answering!
The load is gonna be a inductive with a power factor of 0,8.
That amplifier has an optimum output impedance of 4 Ohm and I think we need of 20 Ohm to get a 100V output signal.
Thanks for your reply!
Carlos
(3,900 Views)
You need 100V rms?peak? peak to peak?  Or a specific power? Or a current?
Strongly depends on the kind of load.    Or just buy a bigger amplifier 🙂
The 500W was just picked by your rating.... (and it's the type we use here with different labels...)
Again, ... for specific needs/questions pick up the phone... that's what applications engineers are for;)
IF you like to heat the solder iron.. have a look at the power amplifiers from APEX
Henrik
LV since v3.1
(3,887 Views)
