Signal Conditioning
MIO for AMUX-64T
I have the following hardware with me: AMUX-64T, SCXI-1163, SCXI-1300, SCXI-1102, NI DAQ4351, PCI 6024.  I have to use the application for thermocouple temperature measurement. The manual for AMUX-64T talks about a MIO board. Which amongst the above is a MIO? I am new. Please help.
(6,485 Views)
Hi IshanG
MIO Refers to Multichannel I/O DAQ boards. It designates a family of data acquisition products that have multiple analog input channels, digital I/O channels, timing, and optionally, analog output channels. An MIO product can be considered a miniature mixed signal tester, due to its broad range of signal types and flexibility.
The above hardware does not have MIO in its name; like a  AT-MIO-64. For example, the AMUX-64T is a front-end analog multiplexer that quadruples the number of analog input signals that can be digitized with a National Instruments MIO board. To address theAMUX-64T with a MIO board use the following link:
http://ae.natinst.com/operations/ae/public.nsf/web/searchinternal/c6d362737414ad6d862562a80070e694?O...
So, none of the above are MIO boards themselves but some are compatible with MIO boards. Do you require manuals or explanations on the hardware you listed?
Your SCXI-1102 module;this is for signal conditioning of thermocouples and might be your best choice of hardware.
Many thanks for using the NI forums and I look forward to your reply.
Kind regards
David
National Instruments UK
(6,298 Views)
To clarify, boards from our E Series, M Series, and X Series are also considered MIO boards.  The PCI 6024 that you mention is one of our E Series boards and is thus considered an MIO board.
Seth B.
Principal Test Engineer | National Instruments
Certified LabVIEW Architect
Certified TestStand Architect
(6,275 Views)
