Signal Conditioning
Noise signal on resistor with VI Voltmeter - usb6218
Hi, I'm acquiring a Volt signal from a resistor with  usb6218. the resistor is connected to a IR photocell . If voltage is high, this mean that there's an obstacle . problem is that I have a noise on the signal and this gives me some problems. you can remove it?  I attach some pictures. Thanks for your help
(6,025 Views)
Hi Giakko!
This post is duplicated here and (in Italian) here.
Please don't cross-post, it makes helping you more difficult.
Lucius
(6,004 Views)
Hi lucius,
ok , i'm sorry.
bye
(6,002 Views)
