Signal Conditioning
Max voltage (ac & dc) that can be applied to a SCXI-1303 input channel
I wish to use my dac system to not only log temperature, but voltage as well. I have:
-PCI 6052E
-SCXI-1000
 -SCXI-1102
  -SCXI-1303
 What is the maximum voltatg that can be applied to a channel of my system. I don't think I will ever exceed 15vdc but I'm not sure right now. I just want to know what not to exceed as far as (AC/DC) voltage in is concerned. Your help is appreciated.
(3,440 Views)
Each SCXI 1102 channel has a software programmable gain amplifier that can be set for following gains
  • Gain of 100 (for thermocouple and other millivolt signals)
  • Gain of 1 (for ±10 V inputs).
so by setting a gain of 1 on a selected channel, you can measure voltages in range of +/- 10 Volts only, not upto 15 volts
Hope this helps
Regards
Dev
(3,432 Views)
