Signal Conditioning
PCI-6221 to SCXI chassis setup in MAX as Traditional DAQ
I am installing a SCXI setup I purchased a few months ago.  In the past I used as PCI-6034E to a SCXI-1100 chassis with a 1100, 1124, and 1160 modules.  The sales rep recommended that I use the PCI-6221 as the DAQ board and I am having trouble in MAX in getting the virtual channels setup.  I am using Traditional virtual channels (Vendor who generated software has a calibration module that must use this).  When I set up the virtual channel, the configuration is invalid and I cannot select the DAQ I/O or channel.
Any suggestions?
(3,621 Views)
sorry to say that this card PCI 6221 does not support Tratitional DAQ.Smiley Sad
It has only DAQmx support.
so you cannot use traditional DAQ virtual channels in this setup
(3,616 Views)
