Signal Conditioning
Parallel and multiplexed modes for SCXI...
I am having difficulty understanding how the Parallel and Multiplexed modes for SCXI modules work.  I've been trying to find one comprehensive document but have been unsuccessful.  Can you please help considering the following configurations:
  1. Single chassis, single module
  2. Single chassis, multiple modules
  3. Multi-chassis, single module on each (I don't know when that would ever be used, but nevertheless...)
  4. Multi-chassis, multiple modules
Also I would appreciate it if you could mention when the DAQ device's onboard multiplexer is used, when the SCXI chassis/module/bus' multiplexer (I don't know where exactly the SCXI-based multiplexing occurs) is used, and when both are used.
Thank you.
(4,681 Views)
These links should help you
http://digital.ni.com/public.nsf/websearch/cc4aa48bbff92ba586256522004eb7e3?OpenDocument
https://www.ni.com/docs/en-US/bundle/320515f/resource/320515f.pdf
Dev
(4,678 Views)
