Signal Conditioning
why does SC-2345 / E Series board have DGND tied to Chassis GND?
Grounding isolation problems with SC-2345 chassis.
In checking the SC-2345 carrier, even with no modules installed, I find that DGND (pin 44 for example) is tied to chassis ground on the computer as soon as the card is connected.  I am connecting directly from the terminal strip on the chassis.  These should be isolated, from all the posts and manuals that I have read.  This problem appears to be true with both the PWR-01 and PWR-02 options.  It does appear AI sense may be isolated, but noise on our digital lines has been resulting in test failures.  How can I isolate my digital signals and specifically my signal ground for encoders using this hardware?  This appears to be true with both an E series PCI-16XE and M series PCI-6251 card.
Thanks in advance for any insights.
(3,952 Views)
None of the DAQ cards you are using are isolated. The 2345's Digital Ground pin is directly connected to the PCI DAQ card - and the digital grounds on each of those is tied to chassis ground.
Can you point me to the resources you found that suggested otherwise?
Thanks!
Abhinav T.
Applications Engineering
National Instruments India
LabVIEW Introduction Course - Six Hours
Getting Started with NI-DAQmx
Measurement Fundamentals
(3,941 Views)
