Signal Conditioning
Performing strain gage shunts on more than on SCXI-1520 module
I am developing an application to apply the SCXI-1314 shunt resistors to 250 strain gages for calibration. I used the SCXI-1520 Strain.vi found in the examples sections of Labview as the foundation of my program. I can not use MAX because I use custom strain gage VIs that convert the input voltage into strain.
My problem is that I can apply the shunt to one SCXI-1520 module only (I found this to be the case even using the SCXI-1520 Strain.vi). How can I apply the shunt resistors to all 250 gages at once?
(4,282 Views)
Hello Mark,
How many modules are you using? Have you been able to test with more than one module? If I understand your question right, you want to know how to modify the VI. Please let me know.Thanks.
-Arun V
(4,280 Views)
Thank you for your response. I am using 34 SCXI-1520 modules. The problem is that I can only shunt the gages in first module using either the SCXI 1520 Strain.vi supplied with Labview 6.1 or my program. All of my research in the SCXI-1520 manual (Dec 03 version) and the NI website does not explicitly discuss using multiple modules. I want to know ifshunting multiple modules is possible (as it was with the SCXI-1121), and if so how do I do it.
(4,280 Views)
I am using shunt cal with multiple SCXI-1520 modules, however, the virtual channels are setup via max. I have not used shunt cal for multiple modules with physical addresses.
Since all the physical channels are the same for each module, maybe you need to run it through a for loop that is auto indexed to a module array.
(4,232 Views)
