Signal Conditioning
SCB-68 Connector
Now's everbody the type from the connector at the SCB-68, I want to design my own connection board for 7831R FPGA-board to connect up to 17 quadratur encoders.
For the connection between my own board and the FPGA 7831R card I'll use the standard SH68-C68-S cable, so I've to buy the same connector as I found on the SVB-68
(6,820 Views)
the connector is a standard SCSI-3 connector. You can order it at www.ni.com. Have a look at the following link:
http://sine.ni.com/apps/we/nioc.vp?cid=4798〈=US
Matthias K
(6,810 Views)
the link doesn't work.
Go to www.ni.com and search for product number 777600-01 or 777601-01
Matthias K
(6,795 Views)
I also bought the connector(NI product number : 777601-01) but there was no footprint offered for my PCB layout. Could someone give me the specification about this connector?
Thank you.
(6,738 Views)
Thank you.
hello,
have a look at the 7831R User Manual at page 55 (B-2). Filename: 370489b.pdf
Just go to www.ni.com and search for "370489b"
Regards
Matthias Kress
(6,725 Views)
The connector is an AMP 2-174339-5. Mechanical drawings and specifications are available at www.amp.com. Search by this part number and take a look at the "Customer Drawings".
(6,715 Views)
