Signal Conditioning
Reusing nulling properties
I have a scxi application with many channels (100+) of various sensory including strain gauges using a 1521b and 1317 front end.  I null the sensors when they are unstrained then perform the shunt calibration and use the sensors and all is well.  If I close the program and start over I want to sometimes reuse this previous nulling so that I dont get a rew reference zero point.  What properties (using labview and daqmx 8.7) are set for this nulling so I can save this to file and then rewrite the property nodes if this is desired by the user.  This is a quarter bridge I connection with a 3 wire strain gauge.  I find that the initial bridge voltage and fine potentiometer do not give enough to use these and pick up where I left off.
I did this with a load cell and it workied using the fine, coarse and initial Voltage to get the bridge settings back to the zeroed state.
Paul Falkenstein
Coleman Technologies Inc.
CLA, CPI, AIA-Vision
Labview 4.0- 2013, RT, Vision, FPGA
(6,891 Views)
Hi Paul,
Are you referring to the process in this knowledge base article?  This second article also indicates the Initial Bridge Voltage property is the way to go about re-using the information.  Can you elaborate on "I find that the initial bridge voltage and fine potentiometer do not give enough to use these and pick up where I left off."?
h_baker
(6,868 Views)
In my application I have many strain gauges, when they are setup using daqmx (not max)  add a strain gauge channes to my task and based on a configuration file that looks up all the parameters about the gauge (gauge factor, lead resistance.....).  Before collecting the data I need to null the bridge (optionally) and then do a shunt calibration.  The Null works fine and so does the shunt calibration and the data looks great.  An additional runs (ie the used terminated the program and restarted)  I want to pickup where I left off, so I do not want to renull the channels but reuse the previous measurments.
When i nulled the gauges, I saved the channel parameters bridge initial voltage and fine pot setting.  I write these properties back to my task channel but I do not get a correct strain.  Im I missing something.
I did this for load cells without an issue, saving the initial voltega and the fine and course pot settings.  Just can not get this working with the strain channels.
Paul Falkenstein
(6,862 Views)
Hi Paul,
I have verified with colleagues that it should work with only those settings.  If you are still having issues with this, then please post a small piece of working code where this is not functioning as expected- thanks.
h_baker
(6,823 Views)
