Signal Conditioning
SCB-68 circuit diagram
Hallo all,
I am having SCB-68 68 pin sheilded connecter block. Can any one provide me electrical circuit diagram?
I have gone through manuals provided, but I have still some queries.
1) how exactly the switches work ?
2) What is need to provide +5v to the signal conditioning part ?( Because for signal conditoning we use some resistors and capacitors )
3) where should we always  connect our signal ? is it always at the screw terminals or is it depends on the signal conditioning requirement ?
4) If we use signal conditioning, what are the signal input terminals ? And from which terminals conditioned signals reaching the DAQ ?
Regards
-Vaidhin.
(7,843 Views)
Accepted by Neo6
Hey,
the Circuit diagramm is shown at these PDF at page 82-83. (SCB-68 68-Pin Shielded Connector Block User Manual)
The Sensor you want to use is ever connect with the Screw Terminal,
The Switches have the following functions:
S1 --> 5V Power Supply
S2 --> DGND
S3 --> AIGND
S4 --> PSE or Differential measurement
S5 --> CJC (Cold Junction Compensation)
Best Regards
Basti
--> I work for KUDOS <--
(7,817 Views)
Hey Basti ,
Thank you very much
Regards
Vaidhin.
(7,812 Views)
Hello
And what about a complete schematic / electrical diagram ?
I'm a beginner and I'm having really hard time understanding how things work !
As ones say, a drawing is better than a long talking !
My SCB-68 is connected to a PCI-6224
(5,777 Views)
