Signal Conditioning
SCB68 how to calculate the correct resistor
OK, good luck with your project and just ask your questions here there is 'always' someone with an answer.
Message 11 of 14
(2,867 Views)
HI!
I am again here 🙂
I was calculating the watt of my 100Kohm resistor. I thought that if my differential analog signal is
between 0V and 5V and my sensor requires 100mA than ... the required resistor Watt is
W=5Vx100mA=0,5Watt
Is it ok?
Sarah
Message 12 of 14
(2,859 Views)
So soon back again  Smiley Very Happy
The Driver/Sensor combination is power by a separate power line (5VDC). The power consumption is 101mA of both boards.
The current through the 100k bias resistors will be less then 1µA. So just a small resistor will do.
Or are we talking about different things  Smiley Surprised
Btw. where are you located. I always like to know where people comming from.
Greetings from The Netherlands
Message 13 of 14
(2,856 Views)
oh...I am a little bit inexperienced 😉
When I went to electrical shop to buy resistors they said me: what power do you want?
oh... Smiley Surprised
thank you very much...again!
I come from Italy... I visited two times Netherlands... very nice!!!
Sarah
Message 14 of 14
(2,853 Views)
