Signal Conditioning
SCXI-1001 rail screw dimensions
I'm not sure if this is the best spot for this but....
I have some custom PCBs that breakout the connections of several SCXI-1130 modules in an SCXI-1001 chassis.  Since I don't want the PCBs to either A) come loose, or B) cause undue strain to the module connector, I have made a bracket that I mount them to.  I want to connect to the rails of the SCXI chassis through the openings in the front panels of the modules.  To do this I need appropriate screws.
I think that the rails are M2.5, but I'm not sure (and I don't want to order and wait for hardware only to find out that I guessed wrong).  Can anyone confirm that the mounting rails on the SCXI-1001 require M2.5 screws?
Sean
(6,532 Views)
Accepted by Sean.C
Sean,
If you are refering to the screws that go in the front of the chassis connecting a card to the chassis they are SCREW,M2.5X8MM,PHIL,PNHD,SS.
Sincerely,
Jason Daming
Applications Engineer
http://www.ni.com/support
(6,523 Views)
James,
Thank you for confirming that I need M2.5 screws.  I won't be able to use the exact screws specified, but it would not have been helpful if I had ended up ordering something with the wrong thread.
-Sean
(6,518 Views)
