Signal Conditioning
SCXI 1125, how do i acquire CJC channel?
Hello
Am using an PXI 8186 embedded controller, with 6280 M series DAQ card, 1125 signal conditioning module and SCXI 1328 terminal block. I want to use the CJC data from a channel, the problem is i dont know which channel will i get the CJC data, is it one of the 8 channels? if yes then i will have 1 less channel per SCXI module is this correct? if yes then which channe l will i get the CJC data?
Thanx for any reply
Arun
(3,364 Views)
Hi Arun,
The following KnowledgeBase should have all the information you need for using the CJC with your setup:
http://digital.ni.com/public.nsf/websearch/5CA3A774944DDBD8862564EB0060234B?OpenDocument
Have a great day!
Brian Spears
(3,364 Views)
Hai
Thanx for the answer Brian, I have read the article you have supplied. but some doubts still remain. I have configured the SCXI and also the terminal blocks. I need to create a virtual channel to read CJC value thru MAX how do i achive it? I cannot find the CJC channel in the listing to create a virtual channel. If i use the "acquiring CJC value" example, the CJC channel and other inbuilt channel are displyed in the list, in the application. Why is it like this? Kindly help
Thanx
Arun
(3,364 Views)
