Signal Conditioning
Triggering voltage at PFI0 (A11 terminal) for SC-2345
I am trying to automatically trigger my data acquisition when I send a voltage (4.5VDC) to the screw terminal of my SC 2345. I was advised to send this voltage to terminal A11 (+4.5V) and to B12 (ground). As long as the SC 2345 is not plugged to the power source (in other words it is not powered on), when I have no voltage 'sent' to the terminal, I am reading to the voltmeter approx. 0 VDC. When I 'send' the voltage to the terminal I read the right value (+4.5VDC). NOW, when I power on the SC 2345, I read ALL THE TIME +4.5VDC to the voltmeter (the voltmeter is a physical instrument, not a vi). In other words, no matter if a voltage is sent or not , I am contin8uously reading the 4.5 VDC.
It is important to have this
on/off voltage at SC 2345 because besides my vi, I have a separate DAQ card that will start working when it gets the 4.5V and will stop recording when voltage drops under 0.5VDC.
What should I do? What seems to be the problem?
If still A11 and B12 are the right terminals, what channel should I select in my vi for this incoming voltage? (to be able to start and stop my DAQ when the voltage comes in or drops to 0, respectively).
(3,235 Views)
Please refer to the email that was sent to you. In the future, please call/email support or use the discussion forums, not both.
(3,235 Views)
