Steve,
It is not the current that causes the SCXI-1162HV to register a "1", it is the voltage level.  As long as the voltage is above 2V DC it will register a "1".  I have attached the specs concerning the voltage levels below.
You should not be concerned as long as the module is working correctly in relation to the input voltage levels.
