Signal Conditioning
SCXI-1162HV Input Sensitivity different from previous modules
I have a number of SCXI-1162HV modules in a chassis, purchased approx. 3.5 years ago. My nre SCXI-1162HV modules only require a fraction of the current required by the originals to indicate a '1'.
Is this important ? We are looking at 2uA to a previous 30uA. Many thanks, Steve Booth
(3,066 Views)
Steve,
It is not the current that causes the SCXI-1162HV to register a "1", it is the voltage level. As long as the voltage is above 2V DC it will register a "1". I have attached the specs concerning the voltage levels below.
You should not be concerned as long as the module is working correctly in relation to the input voltage levels.
(3,066 Views)
