Signal Conditioning
SCXI-1521 and SCXI-1521B
Hello
I am using SCXI-1000 chassis, SCXI-1521 module, SCXI-1317 connector block along with 120ohm strain gages to do a dynamic strain measurement experiment. I learned that SCXI-1521 works only with 350ohm resistors. Do I really have to get a SCXI-1521B module which works 120ohm resistors to do my experiment or get new set of 350ohm strain gages?
One thing I am amazed of is why does NI makes different modules to go with different capacity resistors. I only know about 1521 and 1521B modules and what if anybody uses 240ohm or 1000ohm resistors.. which module should they use?...
I am wondering if anyone know of any work around for me with out changing my module or strain gages.
Thank you in advance
Mekdeng
(3,441 Views)
Discussion of this topic has been moved here.
Eric
DE For Life!
(3,425 Views)
